LJohn
- January 31, 2014
- Piscataway, New Jersey
- 2000 Explorer Eddie Bauer
I have a stock 2000 Explorer with autolamps where the headlights stay on unless a battery terminal is disconnected.
The problem seems similar to many that I have seen in this forum and elsewhere on the internet, but it has not matched any I've seen so far.
I've found that a TSB exists which describes the problem, but I have been unable to obtain a copy of it. The TSB number 15564 information is:
TSB data for: 2000 FORD EXPLORER
Bulletin Number: 15564
Sequence Number: 630100
Date: 20020101
Component Name: 121000 EXTERIOR LIGHTING:HEADLIGHTS
Summary:
SOME 4 DOOR VEHICLES WITH THE AUTOLAMP FEATURE MAY EXHIBIT A
CONDITION OF THE HEADLAMPS STAYING ON ALL THE TIME *TT
Does anyone have access to this TSB? I have never seen it mentioned in any of the "lights stay on" problems for this vehicle.
All fuses check OK.
Initial troubleshooting shows that the autolamp relays are keeping the headlights and parking lights on. Disconnecting the connector on the mirror has no effect. With the ignition switch off, the autolamp relays (headlight relay, parking lights relay, etc.) are normally energized by bringing the common wire connecting these relays close to ground. It should be around 12 VDC to keep the headlights off.
The voltage on that line is not constant, but seems to run around 3 or 3-1/2 volts, which is just about low enough to turn the relays on, which is turning on the headlights.
Any help finding the TSB or in solving the problem would be greatly appreciated.
Date: 20020101
Summary:
All fuses check OK.
