Completed Project - Turboexplorer's Full Width SAS Build Thread | Page 13 | Ford Explorer Forums
Completed Project Turboexplorer's Full Width SAS Build Thread
Use this prefix for completed projects that are not "How to" articles or threads asking for help.
Here is some more pictures of the links. I am debating on filling the upper link mounts on the lower link side with a MIG weld and blending it so it looks like part of the tube just rolls up straight into the mount or to lay a nice TIG weld down. Hummm........
These pictures look way funny. They make it look like the link mounts are way retarded. They aren't. They are however not parallel so to speak since the inner mount is farther rearward than the outer mounts. Makes for a weird picture. :rolleyes:
I also did some lower link bracing to. It is made of 1/8" plate and looks great. When the axle is taken out to final weld things these plates will be TIG welded in place. The upper section or corner will be tapped down so it rolls in nicely to the top of the truss. Will wait to tap that down until the rest is welded so it doesn't break loose.
Looks very nice thus far.
Thanks guys! It's my first real big project so its far from perfect but I am doing my best. I will have more pictures of today's work up tonight. :)
I also talked to Tatton's drive line shop that is doing my rear and the double cardan is a go so tomorrow I can set pinion angle and fully weld everything in and paint the rear so I really hope the rear is 100% tomorrow. (crossing my fingers)
Plug welds done in the upper links. And the hot root pass done on each of the 4 links. They really look great. Had to cool before the final weld is done.
Upper links
Lower links
Looks great and those bungs aren't going anywhere!
Little braces done on the transmission cross member. All that's left is to make the section that will go up to the trans mount and hold it all. Amazing the bends and things it took to keep the cross member up and out of the way on a V8 rig. Lol, glad its over. Still have to make the rear one as well, will go behind the T-Case and then will be tied to the trans cross member and then plated as a skid plate for the T-Case. If I get to it that part isn't critical so it will be last.
These are 2"X.250 wall tubes that are used for the hoop mounts. They will be welded to the plates. I found out today that the shock hoop mounts won't end up dead center on the plates on the frame, :( (they where put there since that's the only flat spots on the frame) It wont be bad just will be a little forward. I had to shift them a little forward because if not I wouldn't be able to change my blower motor ever. That would suck. Still will be wicked tight but should be able to do it. I also had to move the cruise control module as well. Lol, lots of things had to move for these hoops to fit. ABS module, washer bottle, radiator overflow bottle, cruise control moudule. :) Most will be easy to relocate.
Then the hoops themselves are 1 1/2"X.120 wall. Easily strong enough since they are always in tension not compression. They lean from the frame out at a 15* angle. The coilovers will mount on the inside (towards the engine) of the hoops. This will lean the coilovers in a bit so under full compression they will still have a slight lean towards the center of the rig. Help a slight bit with roll resistance, plus give a more linear compression. As the axle swings it will always be in the right spot.
Shock hoop mounts.
Fitting the shock hoops.
Shock hoops tacked in place to the mounts. This way it was easy to fit the hoops to the mounts. I didn't have to bend The hoop to a set point for the mounts. I measured from center to center on the plates and then bent the hoops to where they where at that measurement at the mounting points. Then slid the mounts to the hoops got them all fitted then tacked to the mounts then I can pull the mounts and hoops together and TIG them on. Then I will put them back on the frame and weld the mounts to the plates. This way I can get around both joints to better weld them.
Man those shock hoops are up there. :eek: Man fitting 14" coilovers in a second gen is tight. :) Will be totally worth it though. Tomorrow I will have to make sure all wires and things are on the right side and where I want them before I weld them to the frame or I will be SOL. They would have to be cut to go to the other side of the hoop. But all should fit well. Looks like the brake master and booster are easily replaced if needed. The hardest thing to replace with these in there will be the blower motor. But again I should be able to make that work I believe. No choice where these hoops go so :rolleyes:
See how close to the blower. I will take some pictures from the top tomorrow when the hoops are permanently welded to the frame.
Welding up the hoops to the mounts. Almost done. Have a few sections left on each but had to let them cool and by then it was the end of the work day.
I forgot my camera at the shop today so i wont have any new pictures up tonight. :mad: O well. And I will be traveling all weekend, over 1,000 miles, so I will try to get some up Friday night if possible.
I got the shock hoops tacked to the frame all in place. I will be making the upper mounts for the coil overs tomorrow and when they are fitted right I can then Pull the shock hoops one last time and weld the upper mounts to the hoops then back on the truck to be welded to the truck.
The rear is 100% and is pulled and sitting in my garage so I can paint it on Sunday night when I get back. Then back in the truck Monday. All shock mounts sway bar mounts perches etc are on the axle and fully welded. I like my axle end shock mounts for the rear. :) They are different but will work great!
The double cardan joint is a for sure go so I set the pinion angle pointed towards the T-Case then turned it 2* down so that under power it is straight on and then burned in the perches. Glad to have the rear at 100%
I also got some 1" solid bar stock and put it on the lathe and drilled it out for 7/16 bolts. It will be used as spacers for the steering box. Also as through bolt pieces for where the bolts cross the frame. I am sincerely hoping that the steering box will be in tomorrow. As well as the upper shock mounts done.
Its getting down to the wire and the truck is fighting back hard now. The trac bar will be very interesting. It will be VERY tight in there. Will see what I have to do once the steering box is in. It will have to have some bends but with the 1.5"X.375 wall it will be plenty strong still, but will be a real bear to bend!!!!!!! I have never done it but bending 3/8" wall DOM tube cant be easy.
Anyways that's the updates for today I believe. Hope tomorrow is a wicked productive day.
^ This
:thumbsup::thumbsup:
I can't even comprehend the amount of patience and time you have in this project. It already looks good and its not even done yet
I had to quote above!!!!
Truly Un Believable Work!!!
You have some serious serious skillz!!! I thought your Trans Am was Incredible (still do), But this is just beyond Real!!!
One of my favorite builds Ever!!
And to think I went to A Big Custom 4x4 shop to get a Superfift Suspension Lift done and they refused saying the Torsion brackets would need to be re-welded and it was not possible....
Using the tapered reamer to make the pitman arm able to receive the high angle GM TRE. :) Reamed it nice and slow on the mill and used TONS of cutting oil. For a $90 reamer I sure didn't want to ruin it.
Here is the inside frame plate for the steering box. These are 1" solid bar stock that was put on the lathe and center drilled for the 7/16 bolts for the box. The box isn't flat on the mounting side so these space it so that the box has some solid pieces to bolt to. These spacers where TIG welded to the plate so that now the mounting bolts will be in single shear with a sleeve. This plate will be welded to the inside of the frame and will have sleeves going on top and on bottom of the frame that where done from the same solid bar stock.
