All I can guess would be the drive shaft is still messed up causing the vibrations.
As far as the clunk, have you re-torqued the U-bolts since you installed the new leaf packs? I mark mine against the axle tube and check for movement every now & then. Just a thought.
I really hope the drive shaft is out as being a possibility since It has been redone 4 times now. Not even a change with any of them so with 2 shafts 1 being redone 3 times and 1 100% new one I don't think that is the issue.
Clunk while turning hard was the drive shaft bumping the tank. The trans mount has enough play for it to shift over to the side and bump the tank. Takes a fair bit to get it over there but again was cornering very hard. I have since clearanced the tank but haven't driven it hard enough to check it. But when pryed off to the side the case hits the tank support bracket before shaft can bump the tank so should be impossible for it to hit now.
This! Drive it man. If it's something important it will get worse or break.
I am about to that point! It is terrible and something will let go for sure, it really wouldn't take long for it to show itself but dont want it to damage anything else in the process.
I run our race truck up to pretty crazy speeds in overdrive parked on jackstands in my garage on occasion. Just make sure it's sitting very secure on LARGE stands and go for it. I haven't made the blooper reals yet...
I only have lame small ones that aren't even high enough to leave the tires on the truck. Then I have those really big ones that even at the lowest setting are way higher than I can get the axle and would be 3 feet off the ground even if I could.
Haven't read through the whole thread but are your drive shaft angles still in check? Pinion/tcase in relation to each other and max operating angle?
Try removing front drive shaft and putting tcase in 4hi to see if it may be a shift fork related issue
Also try removing rear drive shaft and putting tcase in 4hi to see if noise changes
Yes all the angles are perfect and don't have an issue. They have been gone over thoroughly and even changed several times and still not a single change in the vibration.
I have ran it in the 4 hi without front shaft and vibration is the same. Run it in full 4WD with hubs locked and with them unlocked and vibration is still the same.
Vibration is not in there when the rear drive shaft is removed but is there when either drive shaft is there. With load with/o load doesn't matter. Just redid the rear gears 100% new bearings and races and a full new gear set and new rear pinion flange. No change in vibration at all.
So its not in the rear diff, rear shaft has been done enough times to eliminate that, ran it without a ring gear locker axles brakes tires etc, I have been through the transfer case and it looked great.
I'm lost.
Only thought I've had the last few days that would be consistent is what if the rear output shaft of the transfer case is bent? It would explain why no matter what I have done it has stayed the same. Would also explain why it doesn't vibrate with/o the rear drive shaft as it would just be wobbling without anything so it just spins there free. But when the drive shaft it on it it forces the shaft to wobble slightly and the yoke then rubs on the tail housing bushing causing the issue. I looked online and found a few on F-150 forums that have had similar issues. vibration at 50-60 the no matter what they redid was still there. Ended up being the output shaft, also a few similar scenarios with the jeep guys before they do the slip yoke eliminator kits.
It's my only thought. Also couldn't tell when the case was apart since there is so many different heights of machined surfaces its impossible to really tell.
Any thoughts? Think this week I'll pull the rear drive shaft again and watch the rear output shaft spin, as I haven't personally watched it yet.
