07EddyB
- November 18, 2011
- Bowling Green, KY
- 2007 Ford Explorer 4.6 V8
Our 22 Explorer had a rattle around the drivers side passenger door at around 65 and more. It's been there since it was new but I finally climbed under today to look. Found a loose plastic retainer that holds up the felt underbody cover. It wouldn't tighten so I took it out and replaced it with two nuts and washers (two nuts because it's a spacer also). Took it out for a drive and problem fixed.
I didn't really like the nuts and washers though - didn't have the right size washers to really hold the felt and I just didn't want them rusting - better to have the plastic back. Took a look at it and decided if I could get at least one set of the arms to grip it would probably tighten. Cable tie to the rescue - it now tightens up enough to not rattle. Would have done both sets but had a clearance issue on the top one.
