Fordy nine
- January 15, 2007
- Clifton New jersey
- 91 Eddie Bauer
I installed my new Dyanmax exhaust from Summit today. My old muffler had no front at all to it, the only reason the pipe didnt fall out was because it was stuck in so far. The resonator was shot and the pipe from there back was totally rusted.
Cut it all out with a sawzall but had to take lower shock bolt out to get new pipe in, no biggie.
Sound is much quieter (I detect a bit of throatyness) but I just want to say I noticed a pretty big time difference in performance. It is more responsive, feels tighter and snappier, quicker, and dosent lug going up hills. You can just plain feel the backpressure. If your not going with a Flowmaster, this is definatly $119 well spent. Tomorrow I want to do the Sea Foam and then change the oil. I cleaned the IAF but didnt clean the MAF because a writeup here said it is self cleaning.
Ok so I have a question,
2 things Id like an opinion on, and ive read many posts but the answer seems mostly opinion oriented
Want to get the front up now, I ordered the WAR153's and a pro comp AAL for the rear. I have Monroe Sense a tracs that are still good. They seem to have enough travel for a 2" , maybe not though. Ill worry about that later.
Are the Daystar 2" lift spacers a good choice? Do they go on top or the bottom of the coil spring? Do i need a spring compressor to get the springs out? Do the ball joints have to be broken? I want as high a lift as possible without resorting to new springs and axle brackets for now.
Can anyone tell me the procedure? Thanks again
