celsoglima
- September 29, 2008
- Location
- South MS
- Hattiesburg, MS
- 00 XLT 3.0L
One of the camber/caster bolts/nuts on the upper control arm on my 2000 Ranger 2WD keeps coming loose. It is the bolt closest to the firewall on the driver's side. The one closest to the front of the vehicle is ok, and so are the bolts on the passenger side.
It is not loose enough for the bolt and nut to come off the vehicle, but loose enough to change the vehicle camber. It also makes a clunk sound everytime I go over a bump. Tire is getting unevenly worn on the inner side.
I have been tightening that bolt to the torque spec, but a week or so later, it gets loose again.
I know I cannot take care of the alignment myself, so I would like to see what needs to be done before I take the vehicle to get an alignment. Both upper and lower ball joints are good, and so is the tie rod.
Has anybody had any issue like that before?
