Camber Caster Bolt w/Replacement Control Arm | Ford Explorer Forums - Serious Explorations
madbrown
Big Sky
1998 XLT
The bolt that comes w/replacement upper control arms is it a camber caster bolt? Or just a standard? I'm replacing mine w/ a Raybestos or Dorman arm, and in the photo it shows just one bolt w/a nut. As I only need 1 anyways, but if not a caster bolt then will need kit. Thanks
I bought the moog uppers and lowers a few months ago. you will need the kit, as they expect you to reuse the stock bolt with the welded washer on it.
tried to get it aligned after and the stealership didnt even have the right tools to do it. had to wait 3 days for the kit from rockauto.
Mine came with a new pinch bolt.
Yeah that's what i misidentified as the camber. So went ahead and ordered a kit. Thanks y'all.
