fedyfedz
- April 26, 2010
- Suffolk County, NY
- 2002 limited v8
those are the exact same ones, there is no welding required for this catback system which is one of the reasons why people enjoy it so much, and the reason there is no write ups on this is probably because it so easy the directions are spot on and there is no confusion anywhere, cut at bend according to directions remove exhaust and install new one in same location using the stock hangers...cant get much easier then that. like i said above the only problem you might run into is rusty bolts on the flange. i would check them before and hit with some wd of pb to losen before removal
