Bob Esseltine
- June 26, 2018
- Chapala, Jalisco
- 2006 Eddie Bauer V8
I have a 2006 V8 Eddie Bauer throwing misfire codes on #5 & #7 cylinders with an occasional intake runner "out-of-range" code. After replacing almost everything else without any success, I am thinking that my intake manifold may have a crack somewhere where I can't see it, the throttle shafts are worn or the CMCV actuator motor is getting flaky. Problem is, the intake manifolds from Ford are NLA (#6L2Z-9424-FA) and there is no aftermarket replacement. I have been able to find a brand new one for the 2009-10 model (#9L3Z-9424-F) at a lower price than what it would cost me to just buy a new CMCV actuator motor. The 2009-10 manifold comes with a new CMCV actuator motor and linkages and looks a lot beefier in the area where it bolts onto the cylinder heads. The only minor difference I can see is it uses a slightly different design with heated PVC fitting on the front of the intake manifold beside the throttle body. The 2006-2008 PCV fitting is heated by coolant, the 2009-10 has an electrical connection instead. The fitting bolts (W709552) may also be a different length.
Anybody have any advice or experience with trying to adapt the 2009-10 V8 intake onto a 2006 V8 Explorer motor?
