sypher9
- April 25, 2011
- Virginia
- 97 Ranger xlt
Hi my names Jonathan and I'm new to the forum. I recently acquired a '97 4.0l ranger xlt 4x4 extended cab with about 106k miles. I've been lurking on the forums for a few weeks browsing all of the information available. I've been having some issues with my transmission and think I need to rebuild the valve body.(I've been looking thru the sticky at the top) Specifically, I have a flare between 2-3 gear. Also it has trouble downshifting on the highway. When the transmission downshifts on the highway, it seems like it hits neutral before going into gear. Most of the time letting off the gas helps it get into gear. After downshifting it doesn't want to shift back into overdrive. Usually if I cut off overdrive and then cut it back on the transmission will shift back into overdrive; or if I come to a stop and then accelerate it shifts like normal. When I first start the truck and take off the transmission shifts fine. It has no problems downshifting, even at highway speeds. Its not until the transmission gets warm that I start having the shifting issues. The downshifting issue isn't as prevalent around town at lower speeds, but I still experience it especially when going up a hill.
troubleshooting done:
I do not know the maintenance history of the tranny, but I recently changed the filter and had it flushed. The fluid in it wasn't burnt, but a little dark. No the fluid is clean(using valvoline synthetic). The pan didn't have anything in it except a little sludge which I cleaned out. I also checked for engine braking in 1 and 2. Engine braking seems to be fine.
I am going to purchase a rebuilt valve body to install, but I wasn't sure if there was anything I was missing. The transmission shop seemed to think there was another issue in addition to the valve body and wanted $550 to open it up and do a full diagnosis. I don't think that is necessary, especially since it works great when cold. With the limited knowledge I have of automatic transmissions I feel like it may be an issue with one of the solenoids? I also forgot to mention that no lights are on and the computer doesn't have any stored codes. I've searched, but didn't see any threads about my shifting issue. Sorry if the post is a little long but I wanted to make sure I didn't leave anything out. Please help!
