n4baf
- September 15, 2005
- Greenville, SC
- 1993 Explorer XLT
I have a 1993 Ford Explorer XLT; while driving yesterday afternoon the vehicle stopped running while I was on the highway. The radio and everything else seem to work fine. The vehicle will turn over without any problems, but want start. I was told that the ignition coil might be faulty. We checked the spark plugs for spark and didn't get any. I have the Haynes repair book and tested the coil. The ohm readings are slighly higher than the specs when testing the secondary coil resistance. The book isn't clear. It says connect an ohmmeter between the secondary termainals. The resistance should be as listed in the specifications. Then it says If continuity doesn't exist replace the coils. I have resistance between the coils, but i don't have continuity. I also noticed that I don't hear the fuel pump engage with I turn the start switch to on. This always happened for about 3 secounds when I turn the key. Does this sound like a faulty ignition coil?
Brian
Brian
