2000StreetRod
Moderator Emeritus
- May 26, 2009
- Greenville, SC
- 00 Sport FI, 03 Ltd V8
I want to purchase a complete 1997 or 1998 SOHC V6 variable induction system to compare performance with my 2000 induction system. I need the upper intake manifold, the vacuum reservoir that mounts between the upper and lower intake manifolds, the vacuum motor with actuating lever, the vacuum regulator/solenoid and its associated connector with wiring pigtail.
I need the vacuum regulator connector and pigtail to use an RPM switch to activate the VIS since my 2000 PCM does not support VIS. No ported intake manifold please. Also, no cracks or broken off pieces.
