Wanting to lift my truck
kindaclean93
Location
good ol commiefornia
cali
1993 Ford Explorer EB
[Links included]
How's this for a lift? I don't wanna go any higher than 4". Also open to suggestions for other lifts, I'm gonna be running 31's on stock rims.
Body lifts also welcome for suggestion. Gonna get my 4WD working eventually, so I'm hoping a lift would give me a good excuse to pull a few things apart and see perhaps what's wrong with it.
410Fortune
Flood Season
Staff member
Moderator
NORTH IDAHO, 7B
B2 "Slightly" Modified
That Skyjacker lift is a GREAT way to get started. Their coils ride really really nice. I have installed it on a few rangers and it yields almost exactly 1.75" of lift in the front which is perfect because any more and you would not be able to align it easily
You will need these:
Camber shims
kindaclean93
Location
cali
Camber shims
Thank you! I wasn't entirely sure of what else I needed, but those shims are it yeah?
410Fortune
Flood Season
Staff member
Moderator
NORTH IDAHO, 7B
You will need shocks, I am surprised it does not come with new front shocks.
Skyjacker black max shocks are very good I am running them on our full size trucks
Buy shocks for a +2 lift in the front, rear shocks factory length will still work fine
So the lift kit comes with new front coils that will get you 1.75" of lift (I can almost guarantee!)
You need the camber shims I posted (or similar, sold under many diff names) These are adjustable from 0 degree to 2.75 degrees (when installed in a 4x4, 3.5 degrees in a 2wd) This will allow you or alignment shop to correct the positive camber the lift coil created
Now you will need extended shocks for the front and new replacement shocks for the rear, unless yours are in good shape
Next consider your options:
The skyjacker kit you posted includes an add a leaf. When lifting an old explorer an add a leaf is not a bad idea, it may actually put some spring back in your factory springs. But also consider using an extended shackle, it can be a good way to lift the rear of an explorer too. Usually easier to install and some people say it improves the ride
Body lift. I only like body lifts to help clear tires. So if you clear your desired tire height with the skyjacker lift, skip the body lift.
If you find you want to go up a size, a body lift can help clear larger meats..... I prefer a 1" or 2" lift on the body, I try to avoid the 3" as it causes stretch in wiring, hoses, cables and steering. Also body lift is expensive and can be labor intensive, raises your center of gravity at the cost of clearing tires.. (I would rather cut sheetmetal to clear the tires)
B Wanting to lift my 94 x Modified 1991-1994 Explorers 10
M Help wanting to fit 31-33s cheap without BL Modified 1991-1994 Explorers 10
P Wanting to do a custom instrument cluster Modified 1991-1994 Explorers 0
F wanting to do a 302 swap on a 91 2wd Modified 1991-1994 Explorers 6
C 2 or 4 inch lift... help me decide please Modified 1991-1994 Explorers 12
K 1st gen explorers with 4in lift and 31s Modified 1991-1994 Explorers 10
1 Is 5 inch lift on 94 explorer enough for 34's? Modified 1991-1994 Explorers 13
9 Which coils interchange with rough country 4" lift brackets? Modified 1991-1994 Explorers 3
4 Rock Trix 2" spacers on 4" RC lift Modified 1991-1994 Explorers 14
C Lift Kit Model Requirement help Modified 1991-1994 Explorers 3
ovrlndr Lift kit purchased...kinda Modified 1991-1994 Explorers 17
B 4 inch lift + soa Modified 1991-1994 Explorers 9
ovrlndr 1st gen explorer 5.5" lift Modified 1991-1994 Explorers 20
shran 2-3" lift - rear spring/shock options Modified 1991-1994 Explorers 13
ovrlndr Lift dilemma Modified 1991-1994 Explorers 5
Exploring XLT 1993 Explorer front lift Modified 1991-1994 Explorers 4
C 1991 X, 4wd lift brackets on a 2wd? Modified 1991-1994 Explorers 0
K looking for 4 inch lift leaf springs Modified 1991-1994 Explorers 10
A 2ish inch lift questions. Modified 1991-1994 Explorers 10
Jim wright Want to put 35s underneath my Ford Explorer got 3 inch body lift Modified 1991-1994 Explorers 5
C 2" lift Modified 1991-1994 Explorers 3
C 6" lift w/TTB = LOTS of negative camber Modified 1991-1994 Explorers 16
V James duff 5.5 lift question/problem Modified 1991-1994 Explorers 1
E 2 inch lift questions Modified 1991-1994 Explorers 17
S Cheap and easy lift kit? Modified 1991-1994 Explorers 11
J 1991 Explorer lift? Modified 1991-1994 Explorers 3
K removing body lift what is the stock bolt length Modified 1991-1994 Explorers 2
F 4 inch lift help needed. Modified 1991-1994 Explorers 3
J 1991 exploder 4 inch lift. 4x4 problems Modified 1991-1994 Explorers 7
T Need help finding a 6" lift Modified 1991-1994 Explorers 2
H Lift Kit Suggestions Modified 1991-1994 Explorers 8
B Lift question Modified 1991-1994 Explorers 3
K rocking side to side after lift Modified 1991-1994 Explorers 7
J looking for a 99 mercury mountaineer 5.0 AWD lift kit Modified 1991-1994 Explorers 0
D Poor Mans Lift Kit Help? Modified 1991-1994 Explorers 4
timtimtimajim Getting ready to lift. Quick questions Modified 1991-1994 Explorers 50
2stroke Sport lift Modified 1991-1994 Explorers 7
9 2 in lift 33s Modified 1991-1994 Explorers 3
HSlough Lift Laws? Modified 1991-1994 Explorers 9
HSlough 4 inch lift? Modified 1991-1994 Explorers 20
B custom lift Modified 1991-1994 Explorers 6
1 Anyone want to sell there rough country 440.20 4in lift kit Modified 1991-1994 Explorers 0
F Duff lift Modified 1991-1994 Explorers 8
96EXXLTinCO PA-793 Body lift for under $30 delivered???? Modified 1991-1994 Explorers 0
9 Explorer Lift Modified 1991-1994 Explorers 6
B questions about lift springs Modified 1991-1994 Explorers 7
8 Ebrake cable with lift Modified 1991-1994 Explorers 2
1 Anything u learned doing body lift could help me Modified 1991-1994 Explorers 1
1 Attn 1st gen guys found cheap body lift Modified 1991-1994 Explorers 0
9 Lift I know I know asked a million times Modified 1991-1994 Explorers 7
Similar threads
