just got quote from shop:
while they won't charge me for the additional re-charge after they repair/replace the hose, I'd be looking at $450. They claim the hose itself is $255 and of course I know I can get it for about $98 at autozone.
Only question now is whether or not...
1. I need a lift (I was told in a previous response no but the shop used a lift to diag the car)
2. will autozone rent a vac and gauge set
3. where would I get the necessary amount of freon needed?
Thanks for the continued guidance.
I would push back on the price. Ask them why does their hose cost $255 when you can get the hose at Autozone without any comercial discount for < $100. The $200 labor I guess is 2 hours @ $100/hour...
Now to your questions..
1: You don't need a lift.. It makes it easier to get to the compressor but jack stands or even "good" ramps will make it easier.
2: Some Chain stores rent the a/c pump but not all..
3: Parts stores and even Harbor Freight tools carry 12 ounce cans of r-134. Last time I looked at the store is was $14/can around here.. Worst case someone can pick up a cans cheap and ship them (UPS ground) to you.. I've been thinking of doing this for people since I'm paying well under $10 per can and some places its just really expensive.
If you were to buy all the tools and parts to do it yourself you would be at around $300-$325.. I can't remember if you need the quick disconnect tools (same tool used for fuel lines).. If so, its $10 for the "set".
As I see it, you would save money now and be able to work on your a/c system later since you'll have the right tools. Personally I like learning how to do things for myself and I got tired of paying $500 for a/c repairs when I could do the same repair for less than $150 in parts.
~Mark
Edit: One thing that just occured to me.. You said "no leaks detected" BUT they say you need a suction hose. If their diagnosis is wrong will they do more repairs for free? If they diagnosed it wrong and you do the work yourself your out the money for a hose you didn't need. You'll still have some new tools though so you can fix it correctly once the right issues if found. Of course, I may have just missed where they said they found the leak or collapsed hose (never seen one). I have seen plugged orifice tubes but that is usually caused by a bad compressor/break down of oil.. the orifice tube can get plugged with metal shavings or black death.
