Joe Fast
- December 14, 2003
- Brooklyn, New York
- 1999 XLT
I have a pain in the #$% problem with my washer pump/related wiring. When I bought the car the front wasker did not work; however, the rear did (same pump). I have tested the unit with a test light and when the switch is hit the wipers work and the pump does get power, but nothing happens. I have swaped out most of the components to see if I can put my finger on the problem but have had no luck. I have swaped pumps, wiper switches and have blown out the lines with compressed air. Nothing different. What I did as a quick fix was swap the hoses on the pump and now the front works when I hit the rear buttton (I needed a way to get rid of the salt on the windshield after snow storms). However it is very anoying to do so because the rear wiper then runs dry. Does anyone know how the system works? are there any hidden relays that could be causing this problem. The dealer is dumb and no one has been of any help around here. ANY HELP WOULD BE GREATLY APPRECIATED.
Thanx
Joe
Thanx
Joe
