mikeinri
- January 18, 2007
- 04 Explorer, 94 XLT (RIP)
Hi guys,
I have a 1993 RV with a Ford E350 Econoline chassis (G-body?). I know, it's not my Explorer, but I think it shares some parts, and you guys are very helpful!
Anyway, the Rear ABS light is on, and the cruise control doesn't work. I took it to a Ford truck dealer, they think it's caused by the aftermarket LED rear tail lights that I installed.
Has anyone ever heard of this? I found a similar problem that affects Corvettes when I did a Google search.
Is there a fix, other than going back to standard-bulb lights? I put the LEDs in because the rear lights were always pretty dim, even after replacing bulbs and cleaning the contacts with a wire brush. I also think that I threw away the original lights (I replaced the entire assembly on each side).
Thanks.
Mike
Thanks.
Mike
