I started the car yesterday and there was a new noise. The car has 380000 miles on it and it was time to consider a new car or do the water pump/timing chain thing again. (last done at 200000 miles) and I had hoped to not have to make a decision until early next year but I gotta decide today.. or if not today very soon. I couldnt find the source of the noise...it seemed to come from everywhere.
I had installed a level detector on the coolant reservoir so I could catch a failed water pump before it damaged the engine I got no alarm from that, and there was no water on the ground. The coolant in fact was at the correct level, I checked the oil no obvious signs of water in the oil (no milkshake consistency) I put a hose against the oil pan (the other end in my ear) I and hear the sound of a fast fiowng stream So I assumed no problem in the bottom of the engine, and then stuck the end of the hose into oil fill hole and same thing, the sound of a babbling brook. So My best guess (worst case) was the timing chain was banging around So I drove it to the shop...(less than a mile)
Just got the call. The noise is as I suspected is coming from the timing chain area So Im looking at spending $2000+ or as the mechanic suggested a used engine (unknown $$) or a newer, used car .
I expected to have to make this decision sooner or later, just not now. And I know what happened is the best thing that could have happened,,,ie I have options. but damn, it couldnt have happened at a worse time for me
Im not asking for advice, although if you have any Im all ears.
Im just *****ing... Thanks for listening
