Blown98
- November 7, 2013
- Chattanooga, Tennessee
- 1998 Explorer 4.0L SOHC
So, here's the story on my 1998 Eddie Bauer Explorer 4.0l sohc. 206,x.. miles, timing components self destructed(from crank to jackshaft and from crank to balance shaft(balance shaft bearings in the oil pan and stuck in the front timing gears, also the plastic guides where destroyed too and small bits of them were coming out at oil changes,as well as chunks when the oil pan was dropped)).
I am at a crossroads here. Since my engine stand prohibits(well, will make it extremely difficult) to perform any type of compression test on the motor, what is the most cost effective means to get my explorer back on the road, considering i cant tell if the engine even still has good compression? Buy a junkyard engine(if i can find one with low miles), go to an online engine seller, or do i just rebuild what i have?
Assuming I CAN rebuild what i have and the engine still has good compression, what would i have to do to rebuild the engine? Just drop new timing components in with a new oil pump? Should i also change out the head gaskets as well? Do i need to spec out all the bearing clearances to make sure i wont have a failure in the bottom end of the motor?
Any guidance here is greatly appreciated here, especially since the sooner I can get this thing back on the road, the sooner i will be out of this cold weather on the bike. And please feel free to ask any questions, i can upload pics as needed if thats what will help in making a decision here.
