JKELLYN13
- July 16, 2015
- Dallas, GA
- 02 Sport Trac XLT
Hello I am a proud owner of a 2002 Sport Trac that is 2 wheel drive with the 4.0 SOHC. It has 205k miles on it and I purchased it with 200k miles on it. Now that it is at 205k miles the rear timing chain cassette or guide has gone out on it. So my question is there are a few options I can go with. I can drop a remanufactured engine in it myself for probably around 3k total dollars. I can go with a used engine with maybe 120k miles on it for around 1700 dollars myself or I could pull the engine and rebuild it myself. What option do you believe would be the most cost efficient option for now as well as down the road? I used to race dirt cars so I'm familiar with engines and that sort of work. Trying to do this the most cost efficient way because my check is the only income for me, my wife and our 2 kids. However I want the truck to last and not just do a band-aid repair either. If the best option is rebuild it should I rebuild just the timing cassettes or the entire engine down to the piston rings? I'm not certain the longevity life on the rings and main and rod bearings as far as if 200k miles on them is a lot or not much. Thanks for any input.
