What temperature thermostat 00 SOHC 4.0 | Ford Explorer Forums - Serious Explorations
bubspc
Las Vegas Nevada
00 XLT
Hi will engine run normal at 180 deg t-stat or is 192 deg t-stat only to run engine normal? 107k miles, I remove t-stats out of my other 70 and 80 vehicles gas and diesels, 120 deg plus soon here, thanks
192/195 will be the correct temp. If you pull your thermostat, expect your truck to get worse mileage, premature wear on the Catalytic Converter.
Not a good idea. If you start overheating this summer, find the culprit. Radiator / Fan Clutch / etc... Truck should have no issue keeping cool.
Ditto. 195 is stock. There should never be a need to pull the thermostat out of any engine in a street vehicle. (Drag racers do it, but they're only running them for a minute at a clip)
-Joe
The 95 and newer Fords have better cooling systems. Unless you alter something, it should keep itself at the proper temperature easily. You can drop to a 180 thermostat for a little cooler running, for your peace of mind if you like.
If your lucky like me, you don't "need" cats in nebraska!
