koda2000
- September 2, 2011
- x
Today I decided to replace the (squealing for a second at startup) serpentine belt on my daughter's '00 RWD Mountaineer 5.0L. That went smoothly enough, but while I was under the truck releasing the belt tensioner, I was shocked to see that both her front tires were extremely worn on the insides, this only seven thousand miles after having a wheel alignment, because I replaced the upper & lower ball joints back in April of this year.
Some of you may recall that this alignment shop is the one that returned her truck with the steering wheel pointing about 15 degrees to the right and telling her see needed to replace her ball joints. The truck went back the next day to have this corrected and they told her that "something was loose". Afterwards, the steering wheel was centered and I thought everything was okay until today. The passenger side front tire is now so badly worn on the inside that the metal cords are beginning to show. The driver's side is almost as bad, but not quite. These are Michelin LTX's with about 20k on them. Now 2 of them are ruined and need to be replaced.
I plan to pay a visit to the shop that did the alignment on Monday, but I'm pretty sure they'll say that it's somehow it's my daughter's fault. Then I'll be calling the BBB. This is supposed to be the most reputable, family owned for 30 years tire/repair shop in my small town. Most all of the other tire/repair shops where I live are so sketchy I never use them. This really pisses me off as now I need to replace 2 tires and pay for another alignment (at a different tire shop!).
