Where does this hose go? | Ford Explorer Forums
fordfordfordford
atlanta, ga
2010 ford explorer eddie
I originally thought the blend door actuator had went bad but come to find out it was the vacuum lines. In removing the actuator this white hose came loose and I can't figure out where it goes. Does it plug in back to this hose end and just make a loop?
<a href="PXL-20220318-154536839"><img src="https://i.ibb.co/nkxHwrz/PXL-20220318-154536839.jpg" alt="PXL-20220318-154536839" border="0"></a>
<a href="PXL-20220318-154553217"><img src="https://i.ibb.co/dkvjRQd/PXL-20220318-154553217.jpg" alt="PXL-20220318-154553217" border="0"></a><br /><a target='_blank' href='Vietnamese Keyboard Online — Useful Web Tool'>number fonts copy and paste</a><br />
"The white "controlled vacuum" line (from HVAC switch) now goes back through the bulk connector, to the glove box area,through several connections and "T's" to the defrost baffle "motor" (diaphragm)-and back through the firewall for controlled vacuum to the Grey coolant bypass valve line." -Turdle
found here How to: - 2nd Gen NO AC ( or heat) FROM VENTS!!! A "How to" what to look for thread
assuming we talking about the same white hose!
(note i cant see pics, so im going by description)
@Fix4Dirt
how accurate is this for 06-10 models?
dang!!! i forgot this was the 4th gen subforum!!! it probably aint accurate, the dash design has probably changed many times over, the design impoved, etc. wish we still had em as pool vehicles, wouldve lliked to tear em apart... hmm... i assume maybe the vacuum driven globe is the same, but the rest i cant be sure about... but then again, ford left alot of stuff constant over the years, and OP did mention something similiar to the picture painted by this, so maybe theyre the same? really cant be srure though! thanks for bringing that to my attn! second time ive done this recently...
