Where does this wire connect to? | Ford Explorer Forums
Shawn McBride
97 Explorer 4L OHV X-code
I just replaced lower intake manifold and got everything connected except for this single green/white stripe wire and would really appreciate if someone know where it goes. Valve cover riser bolt front corner?
The coolant temp sender ( one wire ) should be located in the lower intake manifold, right up front near the fuel pressure regulator.
I believe the oil pressure sender is in the timing cover toward the side.
Both of these have a connection which looks like a threaded stud
Thanks again !
The dark green/white wire is for the oil pressure sender.
