i am trying to use my high beams as the trigger for the relay for my fog lamps. the relays has it's own power from the battery. what color is the wire with current to the high beams? and where is the easiest place to splice into it?
96limitedX said:i just did mine so they come on with the parking lights. so any time the parking lights are on they come on. and they stay on with the high beams. i can look today and find what color the wire is if thats what you want to do?
When I wired in my projectors I directly connected the high beam wires and I could only use flash-to-pass. I needed a diode, you probably need the same.Jason94sport said:Need the same help with a 94. I have:
black
red with black strip
green with black strip
The great hayes pos manual only has the wires for a 91, & it says the red wire, however I spliced that & my lows do not work, but the highs still do. So I guess it's the green wire? Can someone confirm?
