JakePSD
- March 25, 2010
- Ohio
- 2003 Mercury Mountaineer
Got a few questions for you guys regarding a couple 02 sohc 4.0l engines. The explorer has I'm assuming blown head gaskets. It won't run, and even cranking the engine results in coolant being blown out of the reservoir cap. I've already pulled that motor out. I'm getting ready to pull the running motor out of a mountaineer to drop into the ex. I'm considering fixing the ex engine for a spare or to possibly drop back into the mounty if I decide to fix it up.
Since the engines are already out and since the timing components are known to be problematic on these, how long does it usually take to replace the entire system? And what does it usually cost? I'll be doing the work myself, and I'm pretty competent when it comes to working on vehicles. I've seen threads about this in my searching but most are pretty old threads. Not sure how up to date the info is. Also what other things would you guys recommend me do while the engine is in an easy location to work on? Where can I get the timing tools affordably?
