Hotweels
- May 7, 2001
- Calgary,AB
- '92 EB
just finished up the driveline end of my D44-9" swap and took my new toy for a short trip down the back alley... i am having some issues with my brake system....
hard lines... all new lines on front and rear diff
soft lines... OEM rubber from knuckles out
drop lines.... skyjacker SS front and rear 78 bronco
new master cylinder
bypassed RABS valve
new calipers front
75% shoes ford 9" rear no leaks everything look's pretty new
bled about 1/2gal of fluid thru the system
pedal is soft and wont get very stiff with the engine off even after pumping 20-30 times
turn engine on and pedal goes to floor with little effort
any ideas?
will poorley adjusted rear shoes cause this problem? i set them up with a little bit of drag but nothing too aggresive..... my last guess will be the drum's are shot... i dident have them checked
new master cylinder
bypassed RABS valve
new calipers front
any ideas?
