Will a trans from a 98 4x4 work in a 96 4x4 explorer | Ford Explorer Forums
Bigrich954rr
OR
1996 explorer
I have a 1996 explorer with only reverse gear working . I found a transmission on craigslist from a 1998 Ford explore will that trans work in a 96 explorer ?
Not a direct swap, but has been done.
They are both sec gen I have no clue what year trans is in my 99 or my 94
96 with V6 engine has a 4R55E, 98 with V6 engine has a 5R55E. Four speed vs. five speed. They are very similar but the electronics and supportive programming are different.
ok thank you i guess ill look into rebuilding the 96 trans then
Even the gearshift indicators on the dash are different....imp
Imp I didn't even think about that!
Doc
Read the door jamb sticker and decode it, I believe you will find otherwise. Best wishes.
Doc
Like I said I got my tranny from the junk yard all I know is it can from a sec gen
Doc
@drdoom
Reason I thought of that was, my first 5-speed auto is my present 2004. When I got in to test drive it I noted the strangely-different shift markings: P-R-N-D-3-2-1. There was one too many! BTW, ever seen the old, original GM Hydramatic layout? It went, if memory serves me right, N-4-3-2-R. No Park position! When I tore the thing apart, I saw that in "R", with the engine not running, the transmission was locked up by a giant spring, which placed it in 2 gears at the same time. During operation, that spring had to always be released by hydraulic pressure, or the car could not be moved. Learned the first strike against GM engineering with that one! imp
Well I have to say I have never seen one of those! I would be a bit perplexed if I did. Interesting tidbit no less :)
@drdoom
You obviously received your "vehicular indoctrination" after I did. I cut my teeth on Ford stuff in the 1950s, just as the trend towards performance was building. Those countless hours lying on my back under a vehicle in the cold winter of Chicago, were they worth it? Only to the extent that I have never, EVER, paid anyone to do any kind of repair whatsoever, on one of my cars. The cost? One marriage, the worst cost of all. Now, in the twilight of my existence, my second wife agonizes over the questions of what will she do to keep wheels running, when I croak? imp
