Willzilla's 2000 5.0L AWD Turbo Xploder | Page 2 | Ford Explorer Forums
transfer case also uses mercron 5, you may need to replace the rear wire arm and not just the blade.
Ok, so, just the same stuff as the transmission? Cool. How much fluid does the t-case hold? I read the front and rear diffs each hold about 2 qts of their fluids?
I was reading in a few places about the rear wiper arm got a revised unit because the problem I'm describing being a very common one... Now to hunt down the exact part number.
The rear diff holds around 2.5 quarts, front diff around 1.5 quarts, and the transfer case is around 1.5 quarts. If you run synthetic fluids in the rear you may not need the friction modifier. I would just add the diff fluid at first and drive it around a bit, if the clutches chatter than add about an ounce of the modifier, and try again, giving the friction modifier a little time to work itself around to the clutches.
Yeah, the manual calls for synthetic in the rear with friction modifier (i think 3oz or so?) if you have the LSD, which I do... Would it be ok to just play it safe and run that? Rather not have to add, check, add, check, add more, or whatever, lol... Thanks for all the info!! I'd get "reps", but this isn't bodybuilding.com, haha :D
Yes you can run synthetic in the front. You can go ahead and put the friction modifier if you want, less friction modifier just makes the clutches grab a little harder. If you putting synthetic in everything it would Probably be worth finding an amsoil dealer in your area, it's excellent fluid and these days it's a lot cheaper than royal purple, and similar in price to mobil 1.
Thanks... I will look around... I've always ran Mobile 1 in my cars and RP in my SVTfocus... But if Amsoil is good stuff, and cheaper than RP, well... Can't go wrong there... Seems hard to find a lot of options with Mobile 1 where I live outside of the standard oil weights.
Reading around it appears I should be fine without any friction modifier if I run mobile 1 or amsoil in the rear... Like you said :D I will give it a whirl and it looks easy to just add a dab if it chatters!
Looking at the AMSOIL transmission fluid... This won't blow up the transmission or anything as it's "not?" MERCRON V?
their site reccomends the Synthetic Universal Automatic Transmission Fluid, and if you click the more info button it says that it is compatible with mercron V, there are people on this site running it and I've never heard of anyone having issues.
Sounds good... Purchasing a 6 month trial, as well as:
2 qts SAE 80W-90 Synthetic Gear Lube (for front diff)
3 qts SEVERE GEAR 75W-140 Synthetic EP (for rear diff)
2 qts Synthetic Multi-Vehicle Automatic Transmission Fluid (for t-case)
Total was $93, shipped... Cheaper than Mobile 1... Without the 6 month trial membership the cost was a little over $100 shipped.. Nice!
Didn't need to have it shipped, you could have probably found someone local to sell it to you.
Yeah... shipping was only around $7... The closet person was about 40 minutes or so from me... Add that to my laziness and $7 wasn't too bad :D Lol.
More issues/to-do stuff:
- Figure out why the front driver side door lock sometimes does not fully unlock (via remote) and i have to almost force twist and turn the key in the door to get it to fully unlock.
- Mess with the driver side window, it kinds of go up/down a little sluggish and leaves streak marks.
- Fix crack in my windshield from some idiot in a truck tossing a rock into it from his back tire while he was racing around. Crack is a small star and then a 2-3" branch crack from it... Going to use http://www.crackeraser.com/store/983543/?sitecookie=1a09fcade2c29cde27168150fe4042be and hope for the best! Lol.
- TIRES! And maybe new black/gun-metal rims.
- Mess with the hatch... Sometimes it does not want to close completely (latch down into place).
- Hook up wiper fluid reservoir.
- CLEAN CLEAN CLEAN CLEAN!!! Inside & out, lol.
- I'm sure a lot more... :D
Ok... Front hubs have been replaced... Much smooth/quieter! Hooray! :D
Had power steering issue that cropped up (shuttered at low speed when turning the wheel and the power steering pump was very noisy) but went away a few days later.
Should be done this week or early next week:
* copper plugs (gapped .033)
* new plug wires
* vac leak figured out/resolved
* exhaust mapped out/priced: FMS header install, 2.5" pipes Y'd immediately to 3" back to the turbo through a single muffler, no cats, and 4" right off the turbo... Still weighing options on what muffler to run
* t-case, front diff, rear diff replaced with fresh AMSOIL fluids
* fresh synthetic oil and filter
* fog lights replaced with new housing and new super white bulbs
* measurements taken on charge piping and all new piping, couplers, clamps, etc, priced
if you buy another wiper arms thatll work. not sure what the its made of on the '00 but on my 91 my rear wiper didnt make much contact and creaked/banged around. i just bent the arm some and tested the wiper and eventually got to to work perfect
Yeah, I am just going to pick up a new one... It doesn't look too much like something I could bend very well... I think the arms are only like $20 or so online.
