- July 26, 2004
- Willow Grove, PA
- '97 XLT
Question for you guys. Here goes. My old stock fogs in the lower valence are LONG gone. I have two aftermarket fog lights on my rig in the license plate hole - they used to be on either side of the plate that I no longer have because I live in PA now. Additionally, they never did much anyway.
So, I've decided to remove them and add 3 KC 26 series driving lights across the whole plate hole as running lights to supplement my headlights.
Now here's the wiring stuff - bear with me, I'm not the best at this. The two aftermarket fogs are wired directly to the old stock fog lights wiring - that is, power and ground connected right to the old power and ground stock wires via bullet connectors. I intend to wire the KCs up the same way.
Now, that's all well and good, but how should I go about wiring up the third light? Can I just tap right into the power and ground on either the right or left light? Will that be too much for the wires or cause weaker light output? What would be the best/most efficient way to go about this?
Thanks in advance for the help.
