nathaniversen
- February 8, 2010
- Gig Harbor, WA
- 1995 Limited
I have a couple questions about stuff I want to add/do to my truck. It's a '95 Ex Limited.
1. I want to add some automatic auxiliary back up lights to my truck, where is and what color is the wire that feeds the stock lamps when in reverse?
I would like to tap into the power/trigger wire as close to the center console as possible, as opposed to tapping in at the tail lights and running a wire all the way up the truck.
2. Is there a place I can access Hot in Run and/or Hot in ACC switched power that is NOT also Hot in Start?
I would like the hot in run for my back up lights so that they would come on when the key is in Run, but shut off when the truck is cranked to save power for the starter and ignition system. I'd also like the Hot in ACC to hook up my stereo so that it would turn on in Run and ACC but also shut off when the truck is cranked.
