Hi guys,
I had my truck done a few weeks ago.
They did:
-3" PA body lift with Steering extension, remounted Bumpers
-Add a leaf kit
-Torsion Bar Twist
-Warrior Shackles
-KYB AGX Shocks (Replaced Air Ride Control)
-4 corner Tow Hooks
-4 New rotors & pads
-Complete direction redone, higher ball joint with control arms, lower ball joint, tie rods ends, tie rods, sway bar links...
Just had it aligned today, they said I need a camber kit for the rear to correct a very minor negative offset -0.1. But was very straight and wasnt totally necessary. My current tires are gone. Losing air on one because it shows the metal wires on it. I am from Ottawa and winter is coming soon so I need a good tires for all year long. From what the salesman told me, the best tire I should get is BF Goodrich ALL Terrain T/A® KO. Its suppose to be good in mud, snow and ice. Its rated also a winter tire so rubber wont freeze on very low temperature. It gets as low as -45-50 degree celcius here sometimes. They said the BF Mud tires are not good on ice.
I have a 1997 Eddie Bauer, I am keeping everything as is with side steps and 16" wheels. I plan on putting my new tires on my nice Eagle 16" aluminum wheels, they are 8 or 8.5" wide.
With all the mods that I have on my truck. What is the largest tire I can install without any rubbing or trimming? I was planning to go with 285/75/R16 but I wasnt sure if it would rub or not. The best price I found them here in canada is 225$CAD a tire. At that price I want to make sure they will fit well.
Here is a picture that I found here a while ago, I think its running 32x11.50x15, I would like my truck to look like that:
Here is actual pictures of my truck with everything installed:
I would appreciate alot your help and advices. I am planning to purchase my new tires next week.
Also I have a 1997 SOHC Eddie Bauer AWD. Will I need to regear? or my gas mileage shouldnt be too bad? I am doing around 15-16 miles per gallon right now.
thanks for your help
Pat
They did:
-Add a leaf kit
-Torsion Bar Twist
-Warrior Shackles
-4 corner Tow Hooks
Pat
