I was in the same boat as you yesterday! Fortunately for you I think I may be able to help you. You need a slightly more methodical approach then just ripping into the truck and seeing if parts are good or not (I know you're frustrated but that's a really really hard way of doing things lol). First of all, I highly doubt your fuel pump went bad, those don't go out when the truck has been sitting for a year unless there is some underlying problem. The easy way to check this is test the fuel pressure. You didn't mention which motor you had but on the ohv (maybe this is true for the sohc too, I'm not totally sure, I'd hafta double check the manual) there is a test port on the fuel rail. It has a screw on cap (either blue or black) and inside you have a shrader valve (like in a bike tire). If you have the right adapter screw it on there or if you're like me just unscrew that whole thing and screw your gauge into it instead. Make sure you don't get gas in your eyes and make sure the ignition is off because the fuel pump will be on if it isn't. Once the gauge is in turn the ignition on, (you shouldn't have to crank it yet) and you should see somewhere around 30 pounds (might be around 25 if the car has higher mileage on it). Now try cranking the car and see what you get (it should go up to at least 30 and probably will go higher). If you don't pass this test you need to look into the fuel filter and the fuel pump, however I don't think you'll run into any problems here. Next you need to check for fuel in all the cylinders, so pull out all the plugs and see if they're wet with fuel. Make sure you take out all the plugs because you need to be sure each cylinder is getting fuel. In my case I pulled out one plug to see if the whole engine had fuel. Guess what happened to me, I had 5 clogged injectors and I just happened to pick the one that wasn't clogged to test. If all the cylinders aren't getting fuel than you found the problem. Good job now you'll need to get in there and clean out/test each injector.
