410Fortune said:
Hahahahaha I know that feeling! Always takes a bit longer then expected doesn't it? Something ALWAYS comes up too...
Surprisingly, we did not have to make one trip to the store thanks to everything Mechanix had available to us in his garage.
The only major scares we had that I can think of were what we thought were missing parts for the front diff bracket and the rear brake line problem.
There were a lot of other worries but with the ingenuity of everyone there we were able to think through things quite quickly.
410Fortune said:
...Glad you guys got it done, now be CAREFUL doing 75 MPH on a new kit is NOT a good idea. You need to drive it around a bit and tripple check everything you guys installed for a while. Make sure nothing is coming loose, hitting, rubbing, cracking etc. I have spent HOURS under a truck checking EVERYTHING.
I have seen the stories of people installing a new part, getting on the highway or something and BAM, totalled and injured.
Because of the bad weather we had last night we went mostly 55mph the whole 60 mile trip home. When I found a clear spot on the freeway I couldn't help my curiousity and concern about the possibility of vibrations comming from the SOA since we didn't extend the driveshaft or offset the perches. Not to mention the front end should have been completely out of allignment! So I hit the gas!
I couldn't believe how smooth and straight she drove! Definately as good as before the lift if not better. Nonetheless, I will still be getting the allignment checked and adjusted.
We came up with a very easy and accurate method of alligning the rear perches for SOA too-Actually TheRookie's idea-
1) Remove the rear axle and put it on jack stands. Place a jack under the diff.
2) Place a level on the origional perches underneath the axle and use the jack to level the axle.
3) Place a level on your new perches and level them.
4) Double check everything!
5) Weld!
We did one side at a time. Re-checking the level of the lower perches each time.
No we did not offset the perches by 2 or 3 degrees this way but it worked perfectly and I know it's accurate. Didn't need an angle finder either.
