kgb424
- September 22, 2008
- Minden Nevada
- 91 Mazada Navajo LX
my question is when I manually put the transfer case in high,you turn on the ignition key, look at the dash the little 4X4 light is on and so is the light next to the 4 high button, now here is the kicker when I manually put the transfer case in low,then turn on the ignition key the little 4x4 light is on,the light next to 4 high is on again,not the 4 low like it should be, right ????. Is there away to test to see if the 4wd drive switch is good.Could this be my problem why it won't go into 4 low ????. And also is there away to test the position sensor that in the shifter motor assembley. Could this also be my problem ???? I'm getting closer to fixing it permently,I thought about using the double pole,double throw switch, but you are still relying on the shifter motor,but when I've had enough.And I'm getting close to snapping and when I reach the boiling point.I'm going to make manual shifter, but still thinking about it,I want to mass produce them,But I need a 1354 electronic transfer case that I use as a mock up to design something and put a end to the madness,for me and other people, cause I'm sick of dealing with it and I'm sure there is alot of other people are too
