96eb96
- October 20, 2004
- Albany, NY
- 96 EB V6 OHV 4WD
do you have your old one?ok, i have done 2 things this morning
96eb96, i unhooked the electrical connection off of the solenoid under the battery tray like you were talking about, took it around the block, got it up to running temp came back and parked it. started it back up with it still unplugged, no change. killed it plugged it back in and started it, no change. both times i heard the leak.
then i remember when i was getting my iac valve at autozone they guy said there were 2 different ones. so thinking i might have gotten the wrong one, i started it back up and unhooked the iac valve, it dropped down from 1000rpm to about 600 rpm and the leaking noise went away as soon as i unplugged it!
as soon as i plugged it back in the noise comes back like something is leaking.
now this iac valve i bought was brand new.
maybe i have the wrong one?
