- February 2, 2002
- 1998 Mountaineer AWD
Again, power is getting to the PCM sometimes so this isn’t going to be a fuse, or something similar.
Going to take the battery to a different place to be checked. Sure is acting like it might be shorting itself out.Again, power is getting to the PCM sometimes so this isn’t going to be a fuse, or something similar.
Thank you. I'll look for this.The cruise control cutoff switch that was recalled is on the front top of master cylinder. Ford "fixed" the problem by adding a fusible link to the connection. You can see it by a large blue tag on the link. You can buy a new switch for about $24 -- it takes one minute to remove the old and install the new, and then you can get rid of the fusible link.
