- August 1, 2008
- MO MO
- 94 & 95 XLT's
Update: The swap is done & is working well. This has been a year in the making, so it is a lengthy thread with changed directions, good spec info, lots of pictures, silly chatter, trouble shooting, overcoming certain issues that may arise in doing such a swap. I tried my best to include the smallest details of the conversion. Some might seem petty, but to some it might help them along in their work. Enjoy the following & bear in mind I am a novice at best. With pretty limited tools, and practically no physical help, I managed to do this alone in the driveway. The mental help, info, support, and knowledge was given from a collaboration of other members, condensed into a single thread. I thank each and every one that has helped along the way. If I can do it, you can do it!
In this thread you will find:
Complete manual trans & transfercase conversion performed on a 2nd Gen 1995 4wd 4 dr Explorer
Stock 4r55e and 4405-ca replaced with M5OD-R1 & 1354m
Spec information on which trans & t-case years to use
Problem solving with wiring with diagrams & pictures
Shifter installation modifications with a full size console
Exhaust was not removed (thanks to a 3" body lift), so no info on that.
I am going Full Manual in The Black Hole soon.
Picking up a donor - 99 Sport- for all parts needed.
It has the M5R1 Trans, & the 1354 manual T-case. So, I will use everything I can from it for the swap. I plan on finding a ECM from a 95 manual from a Junkyard.
Here is what I am having a problem wrapping my head around with this swap:
Speed sensor!
The 95 has the sensor in the T-case. The 99 has it in the rear Diff.
What can I do to remedy this? I am very green when it comes to fabricating parts, I am limited to bolt on deals if that helps any. So, I don't plan on making a custom Tone ring and welding parts. There must be a way to make this work without having to spend hundreds of dollars on aftermarket speedometers, or a GPS unit. I would like to use my stock cluster and gauges.
Is there any stock Harness that can be used?
Is the ABS sensor hole in my 95 rear diff the same as the 98 & up holes? Will the 99 speed sensor bolt into it?
I searched and looked last night till I had double vision. I did read that there is a rare 4x4 tail house extension with a hole in it for the speed sensor from my 95 sensor. As far as I can tell, that is out, because of how difficult it is to find.
Speed sensor!
