Yankee516
- May 28, 2010
- Long Island, NY
- 94 XLT, 99 5.0L AWD
Evening all,
Noticed a water leak on the top of the water pump on my 99 Explorer 5.0L, so I replaced it figuring it was probably due. Didn't cure the leak, so I am now trying to replace the timing cover gasket. I've removed the harmonic balancer and all the bolts (that I'm aware of), but the darn thing won't come loose. Tried to gently pry it, but don't want to risk warping it.:scratch:
I've removed 19 bolts in total between the water pump and timing chain cover (including the four front bolts from the oil pan).
Could it be that the seal around the shaft is tight enough to hold it in place? I've also read about passing a blade around where the the bottom of cover meets the oil pan gasket to separate. I don't want to damage anything and hope that someone can provide some helpful advice. Thanks for reading!
--Phil
--Phil
