I was sitting around thinking last night about my next step in the project, which is installing the timing cover & it's gasket. So I removed the Fel-Pro gasket from it's box and inspected it. Hmmm - how strange, the Fel-Pro gasket was made out of black gasket paper/material, while the Ford Factory Gasket (that I had removed in one piece) was made out of something that seemed like it was Teflon coated green paper.
As I wrote earlier, the Ford 4.0 OHV engine is manufactured in Cologne Germany. And in the last 30 years of wrenching on my cars is that the Germans (and the Japanese for that matter) ALWAYS have a REASON for why the engineer their cars and engines in the manner that they do, and all it takes is a few corner cutting Americans to screw the whole thing up ;-)
Then I stated thinking to myself that the original Ford gasket peeled off really easily
IN ONE PIECE from BOTH the engine block and timing chain cover after being subjected to 166,000 miles and 13 years worth of driving. Looking at the black Fel-Pro gasket I quickly came to the conclusion that there was no way in hell that in the future, if necessary, it would never come off as easily or in one piece. No doubt I'd have to scrape and wire brush it off of BOTH the engine block and the timing chain cover. Then it hit me why the Germans used the Teflon Coated Paper Gasket, and for confirmation I looked at the following picture:
Now I have no doubt that the Ford of Germany engineers were sucking down some company supplied suds on their hour long lunch break - talking about engineering ideas regarding the 4.0, when they came to the conclusion that when the timing chain cover was removed, the inside of the oil pan was exposed, and that could be a potential problem. If they took the cheap route by placing a "regular" paper gasket behind the timing cover (i.e. Fel-Pro), when the time came to replace it, someone would have to scrape the gasket off of the engine block, and that would risk getting gasket material into the oil pan of their finely engineered 4.0 engine - the mystery of the Green Teflon Coated Paper Gasket was solved ;-) Ford in Germany settled upon the Teflon coated gasket for a good reason, so this morning I went to my local Ford dealership, and purchased:
Ford Factory Gasket Part Number: FOTZ*6020*A for $11.84
This is the gasket that Fel-Pro sells. I have no doubt that it will "weld" itself to both the engine block and timing chain cover...
So after I got home with the Ford factory gasket, I stated buttoning up the engine.
Then I prepped the crank seal and crankshaft snout with Mobile 1 synthetic grease, in preparation for my "Oven Baked" Crank Pulley/Harmonic Balancer Assembly!
Last night I didn't sleep too well because I was thinking about getting the Crank Pulley/Harmonic Balancer Assembly onto the crank. I have to say, getting that damn thing off the crankshaft was a total bee-otch and it took about 2 1/2 hrs on my back. And through the years, I've learned that it's usually much easier to take things apart than putting them back together. So In short, I wasn't really looking forward to this nemt step in the reassembly process. Add to it that I didn't have a harmonic balancer installation tool so I was kinda' at the point of thinking that this is where the project was going to hit a brick wall. I spent a couple of hours on this forum using the search feature, and twice I saw a tip about heating the entire crank pulley/harmonic balancer assembly in the kitchen over at 250 degrees Fahrenheit for at least 30 minutes. Supposedly, according to the tip posters, after heating the crank pulley/harmonic balancer assembly, it was going to slide onto the crankshaft like a hand into a glove. All I kept thinking was "yeah, right - in your world BUT probably not mine." So after lunch, I readied my tools while I was heating the crank pulley/harmonic balancer assembly.
For good measure I smoked a good luck stogie while the I heated the assembly for 40 minutes. When done with my stogie, I put on a pair of leather work gloves, went into the kitchen, removed the assembly out of the oven, and brought it into the garage. I placed it onto the crankshaft, lined up the crankshaft key, and gave the crank pulley a good rap with a piece of 2X4 scrap wood. The assembly went onto the crank for about 1/2", and then it stopped. I grabbed the old crank bolt, coated the threads with thread locker, and spun it in until it bottomed out. I grabbed the ratchet, and started tightening the crank bolt, and lo and behold - the crank pulley/harmonic balancer assembly started to inch it's way towards the engine block really easily - waaaaayyyyy easier than it was to take it off!
Since I was on a roll, I cracked open a ceremonial beer, and then installed the water pump. The water pump uses a standard black paper gasket, and for good measure I coated it on both sides with Permatex Ultra Copper.
