Thanks for that "atta boy" guys!
Yes, it's very satisfying to wake up this morning, knowing that I did the
repair work by myself - but I got a lot of tips and support from this forum - both on this thread and also via PM. Special thanks, in no particular order, are extended to: Texan01, DONO, joe doe, snoranger, ranger7ltr, and 98Ranger4.0
Best tips gathered from this forum/website: Heating the crank pulley/harmonic balancer assembly in the oven before re-assembly was at the top of my list, with how to get off the crank bolt easily was a close second, and using a 1/4" socket extension to facilitate the removal of the crank pulley/harmonic balancer assembly.
If asked what was the hardest part, I'd reply that getting the crank pulley/harmonic balancer assembly off of the crank was easily the most frustrating first, and hardest when you take into account that you have you ensure that the two M8 removal bolts are SQUARE with the pulley (as well as in the correct holes since there are 3), and the fact that you have to take off the removal tool a couple of times while re-adjusting the crank bolt, then removing the crank bolt and installing the 1/4 socket extension. You're performing all of this while on your back, straining your neck, and I'd never, ever attempt this procedure without taking out the Radiator - you've been warned
Also, I'm glad that I was also able to give back and add some of my own tips & tricks to the forum. I never thought a $3 strap wrench would be such a valuable asset - do yourself a favor and buy one for your tool box. I'm extremely happy to show that you guys that you can avoid getting coolant/anti-freeze in your oil pan while performing this repair. I'm very satisfied to figure out why the Ford of Germany engine designers chose to use the green teflon coated paper timing chain cover gasket. Who knows - maybe the mods will choose to add this thread as a sticky?
