00 Mountaineer, ac/heater issues | Ford Explorer Forums
bigforte1
Neodesha, Ks
00MercMountaineer5.0awd
I have a 2000 Mercury Mountaineer that the AC heater motor blower will not turn off. It's got the digital automatic ac/heater but even when turned off the blower motor keeps turning, can get annoying.
@bigforte1 Welcome to the forum! You are real close to me, not many members from Kansas! Let's see the ride?
For your issue, Try a new blower motor relay. Your power box should be real close to this one in the link below.
I hesitate suggesting a relay swap, as the other device will probably stay on also. It is not uncommon for the contacts in a relay to "weld" themselves together which in effect keeps the switch turned on.
If you need, I happen to have a bunch of relays, I could donate one.
Fuse and relay locations--2nd generation power distribution box Layout-
Edit
I am moving this thread to the 2nd generation ( stock 1995-2001 explorers) sub forum.
