Eneurb said:00M12 was the tensioner and the intake gaskets. 01M01 was for the chains and cassettes.
01m01 was only for 97' and 98' oom12 was from 97' to 01'Eneurb said:You've probably got a problem with the cassettes. Those weren't touched on 00M12.
Eneurb said:Yep... you're right... 01M01 covers the front cam chain guide on 1997 and 1998 model years only... that is not to say that I haven't seen this problem on newer SOHC engines...
This would be the tensioner going bad then correct ??kentford said:If the noise goes away you most likely need 00m12 recall but mileage limit is 72k on it also there it a time limit on both recalls to 7yr or 100k warr on 01m01 from start date you may be out.
