kerrygc
- October 28, 2008
- Kelowna, Canada
- 2002 V8 Limited
Hello, I just had the transmission rebuilt and the torque converter replaced on my 02 V8 Explorer 120K.
A couple days after, I started getting ATF fluid dripping from the transfer case.
Looked it up in my Haynes and it suggested checking the level of the transfer case fluid.
When I unscrew the check/fill plug, ATF fluid came pouring out. Is this my problem? Is it overfilled?
The proper level should be at the bottom of the check/fill plug, but it is higher. I was going to drain it to the bottom of the plug but I am off on a trip tomorrow and don't want to do the wrong thing.
Any info would be appreciated.
Cheers.
Kerry
Cheers.
Kerry
