nstevens
- January 28, 2002
- Iowa City, IA
- '95 expedition
I was replacing my lower ball joints this weekend and encountered a serious problem:
The ball joint that is supposed to be a VERY tight press fit into the left front lower control arm now slides in easily by hand. The hole in my control arm had worn and now allows the ball joint to jiggle (guess I've found where my front end vibrations were coming from). When the ball joint is loaded it slips down until the snap ring is wedged into the upper control arm. To say the least, this doesn't strike me as terribly safe.
Has anyone had similar problems and had to replace their lower control arms? If so, did you get the replacement arm from your ford dealer or elsewhere?
The other easier and cheaper solution (for me anyway) would be if one of the ball joint manufacturers supplied an oversized part (say 0.010" or so) that would press into the worn hole in the lower control arm. This is pretty unlikely though.
Any ideas would be great.
