Been there, done that...twice in the last 8 wks. Save yourself a lot of time and money and resist buying the Four Seasons & Dorman t-stats. Go with the Motorcraft conversion and be done with it.
I first installed a Four Seasons (which I believe is a Division of Dorman) and it lasted all of about 2 wks before it, too, started leaking. Unfortunately, this was before I had read all about the problems others had with these two brands. Replaced it with the upgrade Motorcraft housing and all is well after several wks and approx. 800 miles...even as the weather has gotten cold. So, pull up the Rockauto website and purchase these parts:
Pt.# RH144 - Lower T-Stat Housing @ $35.79
Pt.# RG614 - Lower T-Stat Housing Seal @ $3.46
Pt.# DY1269 - Sensor @ $21.79
Pt.# SW6146 - Sensor @ $21.79
Reuse existing Upper T-Stat Housing
You'll need the (2) metal clips that hold the sensors in place. Several sources for those:
Ford Pt.# W706800-5303
Dorman Pt.# 800-019
NAPA Pt.# NOE7305034
Don't forget to install a new thermostat o-ring...and may as well replace the thermostat at the same time. Oh...and, might consider replacing the short bypass hose that connects to the water pump while you're in there, too.
