allmyEXes
- February 6, 2016
- No. Alabama USA
- 1997 Blue Ex 4.0 SOHC
- Callsign
- KAGG 3611 (CB)
@Rick I'm just about ready to order some braided SS fuel line. I see that you Rick have used a few feet of it in the past. I found some hose that I wanted you to check out the specs on. The inner material is CPE. Is this the "norm" for braided line?
- Application
Universal, Great for coolant, fuel, diesel, oil, hydraulic fluid, pump gas, alcohol and air.
100% Brand NEW
CPE braided hose mostly can be work with coolant, diesel, oil, hydraulic fluid, pump gas, air and fuel.
Please notice that the service life might be shorter when it work with fuel.
This braided hose can be used in brake system, fuel pump, fuel filter, oil return, fuel return system, turbo cooler system, and transmission system, oil cooler kit, etc.
Stainless steel braid cover for excellent flexibility and resistance to abrasion.
Inner material chlorinated polyethylene (CPE)
Work pressure 1000PSI
Burse pressure 6000PSI
Working temperatures -40F to 257F(-40c to 125C)
Size detail
4AN ID 5.56MM/0.22IN OD 11.18MM/0.44IN
6AN ID 8.73MM/0.34IN OD 13.89MM/0.47IN
8AN ID 11.13MM/0.44IN OD16.28MM/0.64IN
10AN ID 14.29MM/0.56IN OD 20.24MM/0.79IN
Not recommended installation in corrosive environment, braided fuel line's service life will be influenced.
Outer nylon braided has excellent inflaming and safer to use.
Professional installation is highly recommended.
