allmyEXes
- February 6, 2016
- No. Alabama USA
- 1997 Blue Ex 4.0 SOHC
- Callsign
- KAGG 3611 (CB)
By the way, I did find the DTR switch off of the '99 Crown Victoria but before I did, I was looking up a new DTRS for Crown Victorias and 1999 Explorers and determined that they are different. So that meant that I needed a new switch anyway. If anyone needs a good used "PRNOD2" switch for a 1997 to ~1998 Explorer 4R70W or a 1999 Crown Victoria 12 pin DTRS, dm me.
@CDW6212R I had to come up with a spot for the CHT sensor for two reasons. The stock 1999 Crown Vic P71 cop car PCM (factory PATS off) only had a CHT sensor and the bin file for 1999 Crown Vics that Michael P disassembled and created the definition file for, didn't ever have a patch written/ created to convert from CHT sensor to ECT sensor. However, if the 2003 Ford full size sedan PCM is used, Michael P has defined that bin file almost entirely and written the CHT sensor to ECT sensor "patch" file. The 2003 bin files are too advanced to use in the 1999 version of the PCMs.
Does that make sense early here this morning while I'm still half asleep?
@Josh P I hope that Josh wouldn't mind if I snag the CHT sensor out of (his) the 1999 4.6 Crown Vic if it would be easy to get to. It is under the plastic intake. I would like to have it to make some measurements from it.
