SuperGordo
- May 28, 2009
- Las Vegas, NV
- 2022 Explorer ST
Once I get the engine running again I'll have to plan to reinstall the door panels, the seats and finish installing the interior. Nothing really terrible left to do inside. I still have to clean up the wheels, and plan on the new tires. None of the existing tires are roadworthy in any way at all. The last things I want to do is get it on the lift and replace the rear wheel bearings and seals, and new gear oil. And after that see how bad the rear main leaks. When I first started it it was dripping on the ground and the cat. But none of the PCV system was correct. I have no issue doing the rear main. But that will happen on the lift. But If I pull the trans I'll overhaul the 4r70w at the same time. Then there would be almost nothing to worry about driving wise. Also I'm going to rekey the door locks and tailgate lock to match the ignition. On the tailgate I'm installing a new wiper arm because its just gone. And I'm going to replace the lock actuator back there. I figure that once those things are done I can reinstall the trim panel and not have to go back in there for years. The actuator back there works but some times you have to hit the button a couple times to get it to lock. Don't want to leave it that way.
And If I can muster the budget I'll take this to my exhaust guy for a complete new exhaust system, minus that 3rd cat assembly
