SuperGordo
- May 28, 2009
- Las Vegas, NV
- 2022 Explorer ST
Easily?? hehehe.. my best friend and I really turned the needle on this EX. But my daughter is having all the fun driving it!! I took it for a drive before and after the brakes....wish I had built it for myself...@SuperGordo Good to know! I love following a good build thread, particularly when everything comes together easily. At least we know somebody's having a good time!
It's doing well! Glad you hear you are getting things done on yours! Progress is always good!Just thought of you and your Explorer yesterday bro ! .... "wonder how she's doing" ....
I just got two things resolved with mine in the last week.... good feeling...
Whatever it takes to get the job done!@SuperGordo Easily, relative to hack, slash and weld jobs that require using parts from half a dozen other Explorers!![]()
You replaced those shoes? They look good to me.Changed all the pads and rotors this week. As well replaced the parking brake shoes and did an oil change. Good news is after 6 months, the EX didn’t lose any oil. Shows no signs of leaking on the engine or rear end. So all the work done to date is holding. Everything looks good.
View attachment 434002 View attachment 434003 View attachment 434004 View attachment 434005 View attachment 434006
You know me! I throw unneeded parts at cars all the time with the parts cannon!!You replaced those shoes? They look good to me.![]()
An important tool for every tool box!Parts cannon !I have one of those too ...
That's what she said......An important tool for every tool box!
So after just about a year of driving we've encountered the first real problem. The EX started to overheat last night. My daughter made it to my house. And it was low on coolant. It was late and dark but I can see coolant is leaking from somewhere. But very slowly. But I have to chase this down very shortly.
on my SOHC the worm gear clamps like to loosen up every once in a whileWorth noting that it's likely a loose hose clamp. I can see a light amount of coolant on the serpentine belt. Everything else is dry. I pressure tested the system and nothing came out. So we'll see.
Check that water pump.
I will check the water pump, but I did replace it when I put this EX together. But new stuff does go bad, so we'll see.Water pump may have a weep hole if it’s leaking from there it’s time for a new waterpump
The coolant went somewhere!
