danwaters
- June 1, 2003
- Fallbrook, CA
- 97 Explorer 5.0 limited
Ya thats good to know. I am relieved my brake system is finally good to go, but I notice even going through a drive thru line or something that my calipers will hit the LCA bump stop, so I will have to figure something out. Maybe if I had robert build some uppers AND lowers he could built them in a way where they wouldn't hit, I just dont know though (im still learning all this suspension stuff), or maybe I will just drill out a bolt hole like you mentioned and use that has a stop, put a rubber grommet on the end or something. That reminds me that my ABS/Speed sensor threading is stripped, I need to get that fixed too...so many small things.
As for the alignment, I have a local guy (DJ auto doctor in oside) who will fix my toe, camber everything tomorrow (mentioned in your PM) ... My alignment and everything was good with just the spindle lift, it was only after the TT did everything get out of whack...but there is still rubbing unless I do the TT. Maybe those new uppers will help out with the ride quality (not that its a major concern)
Edit: I was just crawled up under there, it looks like I would have to have the steering stop facing upwards in order to contact the base of the spindle, if I ran a bolt straight out from the bump stop it would still just hit the caliper. Maybe the simplest thing to do would be to just grind that bump stop off altogether
Edit #2: If anyone could please recommend me the best way to get a performance tune, and speedometer calibration for the 33" tires and upcoming 4.30 gears, that would be appreciated.
Ya, with my arms my steering locks out before I hit the caliper so it hasnt happened to me in a few years. It will still happen with just an upper and that upper wont improve your ride quality. it will just add about an inch of travel if the shock permits it to. As far as your gears...the 4.30s will bring your speedo back to accurate within like 2 percent.
